Saltar al contenido principal
Olympus 850SW Memory Card Replacement
  1. Olympus 850SW Memory Card Replacement, Memory Card: paso 1, imagen 1 de 1
    • Locate the memory card latch/ battery latch on the bottom panel of the camera and open it.
    • Make sure to remove the battery before trying to remove the memory card.
  2. Olympus 850SW Memory Card Replacement: paso 2, imagen 1 de 1
    • Hold the memory card so that the pointed wedge is facing up and the sticker is facing the front of the camera.
  3. Olympus 850SW Memory Card Replacement: paso 3, imagen 1 de 1
    • Hold the card so that the thicker end of it is to the right, and the flat end is facing the bottom of the camera.
    • Insert the card into the compartment fully until it clicks into place.
  4. Olympus 850SW Memory Card Replacement: paso 4, imagen 1 de 1
    • Close the memory card latch/ battery latch.
Conclusión
Una persona más ha completado esta guía.
Un comentario
How much gigabytes can I use on an Olympus 850 SW?
Yuan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 45
Todo El Tiempo: 1,667
