Saltar al contenido principal
Olympus 850SW Battery Replacement
Qué necesitas
  1. Olympus 850SW Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery compartment on the bottom panel of the camera.
  2. Olympus 850SW Battery Replacement: paso 2, imagen 1 de 2 Olympus 850SW Battery Replacement: paso 2, imagen 2 de 2
    • Using a PH00 Phillips Screwdriver, unscrew the one screw located on the latch.
  3. Olympus 850SW Battery Replacement: paso 3, imagen 1 de 3 Olympus 850SW Battery Replacement: paso 3, imagen 2 de 3 Olympus 850SW Battery Replacement: paso 3, imagen 3 de 3
    • Find the arrows on the compartment, remove the small black plastic piece, and release the latch.
  4. Olympus 850SW Battery Replacement: paso 4, imagen 1 de 1
    • Allow the latch to completely open and insert the battery, with the writing side up.
    • The battery slot is the bigger slot. The smaller slot is for the memory card.
  5. Olympus 850SW Battery Replacement: paso 5, imagen 1 de 1
    • Close the latch. You will hear a click when the compartment is fully closed.
  6. Olympus 850SW Battery Replacement: paso 6, imagen 1 de 1
    • Place the small black piece back in its' place.
  7. Olympus 850SW Battery Replacement: paso 7, imagen 1 de 1
    • Place the metal cover back over the closed latch, and screw the screw back in.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 780
