Saltar al contenido principal
Ohmeda Engström Compressor Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Ohmeda Engström Compressor Replacement, Compressor: paso 1, imagen 1 de 1
    • Ensure the device is powered off and unplugged
    • Disconnect any wires or components that are plugged in prior to repair
  2. Ohmeda Engström Compressor Replacement: paso 2, imagen 1 de 1
    • Tap the back end of a flat head screwdriver with a hammer to wedge the side trim pieces away from the machine.
  3. Ohmeda Engström Compressor Replacement: paso 3, imagen 1 de 1
    • Use the flat head screwdriver to pry off and remove the side panels
    • When prying off the panels, do so carefully so that you do not to scratch or damage them
    • When reassembling the side panels, make sure that the connectors snap back into place.
    • Remove the mounting hardware from the compressor on the cart
  4. Ohmeda Engström Compressor Replacement: paso 4, imagen 1 de 1
    • Screw in the service tool to assist in lifting the compressor and sliding out of the cart
Conclusión
Kobe Hayashi
Miembro Desde 02/07/20
269 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G6, Paton Spring 2020 Miembro de Cal Poly, Team S7-G6, Paton Spring 2020
CPSU-PATON-S20S7G6
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 150
