The base is connected to the chair either with retaining clips or nuts and bolts at its center.
Remove the retaining clips or unscrew the nuts and bolts with a wrench or drill.
Remove the base of the chair.
Place a pipe wrench on the gas cylinder, and spray it with WD-40 to lubricate it and make it easier to remove.
Twist and pull the wrench to loosen the cylinder and remove it from its place.
Be sure to follow the instructions for your specific gas cylinder, since installation procedures may vary.
Place the tapered part of the cylinder into the column and rotate it into place.
Reconnect the base of the chair.
Place the chair upright and adjust the chair to your preferred height. Test it out by sitting on it.
Incrustar esta guía
Elige el tamaño y copia el siguiente código para insertar esta guía como un pequeño widget en tu sitio web o foro.
Vista previa
