Saltar al contenido principal
Office Chair Gas Cylinder Replacement
Qué necesitas
  1. Office Chair Gas Cylinder Replacement, Gas Cylinder: paso 1, imagen 1 de 1
    • Place the chair horizontally, putting it on its side.
  2. Office Chair Gas Cylinder Replacement: paso 2, imagen 1 de 1
    • The base is connected to the chair either with retaining clips or nuts and bolts at its center.
    • Remove the retaining clips or unscrew the nuts and bolts with a wrench or drill.
    • Remove the base of the chair.
  3. Office Chair Gas Cylinder Replacement: paso 3, imagen 1 de 1
    • Place a pipe wrench on the gas cylinder, and spray it with WD-40 to lubricate it and make it easier to remove.
    • Twist and pull the wrench to loosen the cylinder and remove it from its place.
  4. Office Chair Gas Cylinder Replacement: paso 4, imagen 1 de 1
    • Look up the chair's part number to find which gas cylinders are compatible with your chair.
  5. Office Chair Gas Cylinder Replacement: paso 5, imagen 1 de 1
    • Be sure to follow the instructions for your specific gas cylinder, since installation procedures may vary.
    • Place the tapered part of the cylinder into the column and rotate it into place.
    • Reconnect the base of the chair.
    • Place the chair upright and adjust the chair to your preferred height. Test it out by sitting on it.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 29
Ultimos 30 días: 158
Todo El Tiempo: 10,280
