Saltar al contenido principal
Oculus Rift CV1 Facial Interface Replacement
Qué necesitas
  1. Oculus Rift CV1 Facial Interface Replacement, Facial Interface: paso 1, imagen 1 de 1
    • Pull firmly from the top of the headset facial interface to remove the foam frame.
  2. Oculus Rift CV1 Facial Interface Replacement: paso 2, imagen 1 de 1
    • Remove the six T3 4mm screws from the top and bottom edges of the case.
  3. Oculus Rift CV1 Facial Interface Replacement: paso 3, imagen 1 de 1
    • Insert the spudger underneath the edge of the lens on the left or right side.
    • Slide the spudger upwards and around the edge of the frame to undo the tabs underneath.
    • Repeat for the other side of the frame.
  4. Oculus Rift CV1 Facial Interface Replacement: paso 4, imagen 1 de 3 Oculus Rift CV1 Facial Interface Replacement: paso 4, imagen 2 de 3 Oculus Rift CV1 Facial Interface Replacement: paso 4, imagen 3 de 3
    • Lift up the frame to see a tab hidden underneath the lycra mesh along the edge of the lens.
    • Pull up on the tab with the spudger.
    • Repeat for the corresponding tab on the other lens.
  5. Oculus Rift CV1 Facial Interface Replacement: paso 5, imagen 1 de 1
    • Lift up on the plastic frame around the lens.
    • Slide a finger around the inside edge, pulling outward from the center of the lens to release the other tabs.
    • Repeat for the frame on the other lens.
  6. Oculus Rift CV1 Facial Interface Replacement: paso 6, imagen 1 de 1
    • Pull up along the outer frame.
    • Remove the facial interface.
Conclusión
Una persona más ha completado esta guía.
Kyle Anderson
Miembro Desde 01/24/19
226 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S18-G4, White Winter 2019 Miembro de Cal Poly, Team S18-G4, White Winter 2019
CPSU-WHITE-W19S18G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 49
Todo El Tiempo: 4,757
