Saltar al contenido principal
OPPO N1 Rear Case Replacement
Qué necesitas
  1. OPPO N1 Rear Case Replacement, Rear Case: paso 1, imagen 1 de 1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Rear Case Replacement: paso 2, imagen 1 de 2 OPPO N1 Rear Case Replacement: paso 2, imagen 2 de 2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
Conclusión
9 personas más completaron esta guía.
Max Pietsch
Miembro Desde 09/26/14
753 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 13-5, Staggers Fall 2014 Miembro de USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,906
