Saltar al contenido principal
OPPO N1 Headphone Jack and Speaker Cover Replacement
Qué necesitas
  1. OPPO N1 Headphone Jack and Speaker Cover Replacement, Rear Case: paso 1, imagen 1 de 1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 2, imagen 1 de 2 OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 2, imagen 2 de 2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Headphone Jack and Speaker Cover Replacement, Battery: paso 3, imagen 1 de 2 OPPO N1 Headphone Jack and Speaker Cover Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 4, imagen 1 de 1
    • Use the tweezers or your fingers to remove the sliver plates.
  5. OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 5, imagen 1 de 1
    • Remove the black plate with your fingers.
  6. OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 6, imagen 1 de 3 OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 6, imagen 2 de 3 OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 6, imagen 3 de 3
    • Use tweezers or your fingers to pull up the connector tabs.
  7. OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 7, imagen 1 de 2 OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 7, imagen 2 de 2
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
  8. OPPO N1 Headphone Jack and Speaker Cover Replacement, Headphone Jack and Speaker Cover: paso 8, imagen 1 de 1
    • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
    • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
  9. OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 9, imagen 1 de 2 OPPO N1 Headphone Jack and Speaker Cover Replacement: paso 9, imagen 2 de 2
    • Use tweezers or your fingers to remove the plastic cover.
Conclusión
3 personas más completaron esta guía.
Joshua Stone
Miembro Desde 09/26/14
1,064 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 13-5, Staggers Fall 2014 Miembro de USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 1,466
