Saltar al contenido principal
OLPC XO-4 Touch Wireless Card Replacement
Qué necesitas
  1. OLPC XO-4 Touch Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Wireless Card Replacement: paso 2, imagen 1 de 2 OLPC XO-4 Touch Wireless Card Replacement: paso 2, imagen 2 de 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Wireless Card Replacement: paso 3, imagen 1 de 2 OLPC XO-4 Touch Wireless Card Replacement: paso 3, imagen 2 de 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: paso 4, imagen 1 de 3 OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: paso 4, imagen 2 de 3 OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: paso 4, imagen 3 de 3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Wireless Card Replacement: paso 5, imagen 1 de 3 OLPC XO-4 Touch Wireless Card Replacement: paso 5, imagen 2 de 3 OLPC XO-4 Touch Wireless Card Replacement: paso 5, imagen 3 de 3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Wireless Card Replacement: paso 6, imagen 1 de 1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Wireless Card Replacement: paso 7, imagen 1 de 2 OLPC XO-4 Touch Wireless Card Replacement: paso 7, imagen 2 de 2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Wireless Card Replacement, Screen: paso 8, imagen 1 de 1
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Wireless Card Replacement: paso 9, imagen 1 de 2 OLPC XO-4 Touch Wireless Card Replacement: paso 9, imagen 2 de 2
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Wireless Card Replacement: paso 10, imagen 1 de 3 OLPC XO-4 Touch Wireless Card Replacement: paso 10, imagen 2 de 3 OLPC XO-4 Touch Wireless Card Replacement: paso 10, imagen 3 de 3
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Wireless Card Replacement: paso 11, imagen 1 de 1
    • Remove the screen from the laptop.
  12. OLPC XO-4 Touch Wireless Card Replacement, Back Cover: paso 12, imagen 1 de 1
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
  13. OLPC XO-4 Touch Wireless Card Replacement: paso 13, imagen 1 de 2 OLPC XO-4 Touch Wireless Card Replacement: paso 13, imagen 2 de 2
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
  14. OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: paso 14, imagen 1 de 3 OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: paso 14, imagen 2 de 3 OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: paso 14, imagen 3 de 3
    • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
    • Gently pull out the two antenna connectors by pulling them away from the motherboard.
  15. OLPC XO-4 Touch Wireless Card Replacement: paso 15, imagen 1 de 1
    • Remove the black 4mm Phillips #1 screw holding the wireless card in.
  16. OLPC XO-4 Touch Wireless Card Replacement: paso 16, imagen 1 de 2 OLPC XO-4 Touch Wireless Card Replacement: paso 16, imagen 2 de 2
    • Remove the wireless card from the laptop by gently sliding it out of its socket.
Conclusión
Zach Yasuda
Miembro Desde 01/24/13
173 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-29, Amido Winter 2013 Miembro de Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
Miembros de 4
20 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 425
