Saltar al contenido principal
OLPC XO-4 Touch Lower Case Replacement
Qué necesitas
  1. OLPC XO-4 Touch Lower Case Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Lower Case Replacement: paso 2, imagen 1 de 2 OLPC XO-4 Touch Lower Case Replacement: paso 2, imagen 2 de 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Lower Case Replacement: paso 3, imagen 1 de 2 OLPC XO-4 Touch Lower Case Replacement: paso 3, imagen 2 de 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Lower Case Replacement, Keyboard: paso 4, imagen 1 de 2 OLPC XO-4 Touch Lower Case Replacement, Keyboard: paso 4, imagen 2 de 2
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. OLPC XO-4 Touch Lower Case Replacement: paso 5, imagen 1 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 5, imagen 2 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 5, imagen 3 de 3
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. OLPC XO-4 Touch Lower Case Replacement: paso 6, imagen 1 de 2 OLPC XO-4 Touch Lower Case Replacement: paso 6, imagen 2 de 2
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. OLPC XO-4 Touch Lower Case Replacement: paso 7, imagen 1 de 2 OLPC XO-4 Touch Lower Case Replacement: paso 7, imagen 2 de 2
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
  8. OLPC XO-4 Touch Lower Case Replacement, Lower Case: paso 8, imagen 1 de 2 OLPC XO-4 Touch Lower Case Replacement, Lower Case: paso 8, imagen 2 de 2
    • Close and flip the laptop over so you are looking at the battery compartment
    • Remove the five 4mm Phillips #1 screws from inside the battery compartment
  9. OLPC XO-4 Touch Lower Case Replacement: paso 9, imagen 1 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 9, imagen 2 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 9, imagen 3 de 3
    • Flip the laptop over, showing the top of the device.
    • Open the laptop and rotate the screen ninety degrees.
    • Tilt the screen so the lower right corner of the screen is closer to the lower case.
  10. OLPC XO-4 Touch Lower Case Replacement: paso 10, imagen 1 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 10, imagen 2 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 10, imagen 3 de 3
    • Push in and lift up on the keyboard edge of the white handle piece.
    • Pull the piece towards yourself to remove it from the laptop.
  11. OLPC XO-4 Touch Lower Case Replacement: paso 11, imagen 1 de 1
    • Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
  12. OLPC XO-4 Touch Lower Case Replacement: paso 12, imagen 1 de 2 OLPC XO-4 Touch Lower Case Replacement: paso 12, imagen 2 de 2
    • Pry off the rear green trim piece.
  13. OLPC XO-4 Touch Lower Case Replacement: paso 13, imagen 1 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 13, imagen 2 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 13, imagen 3 de 3
    • Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
    • Slide the green trim pieces away from the screen.
    • This should release the entire bottom portion of the laptop.
  14. OLPC XO-4 Touch Lower Case Replacement: paso 14, imagen 1 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 14, imagen 2 de 3 OLPC XO-4 Touch Lower Case Replacement: paso 14, imagen 3 de 3
    • Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
  15. OLPC XO-4 Touch Lower Case Replacement: paso 15, imagen 1 de 2 OLPC XO-4 Touch Lower Case Replacement: paso 15, imagen 2 de 2
    • Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
    • There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 3-30, Amido Winter 2013 Miembro de Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 336
