Saltar al contenido principal
Introducción
Use this guide to replace a broken keyboard.
Partes
No se especificaron partes.
  1. OLPC XO-4 Touch Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Keyboard Replacement: paso 2, imagen 1 de 2 OLPC XO-4 Touch Keyboard Replacement: paso 2, imagen 2 de 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Keyboard Replacement: paso 3, imagen 1 de 2 OLPC XO-4 Touch Keyboard Replacement: paso 3, imagen 2 de 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 OLPC XO-4 Touch Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. OLPC XO-4 Touch Keyboard Replacement: paso 5, imagen 1 de 3 OLPC XO-4 Touch Keyboard Replacement: paso 5, imagen 2 de 3 OLPC XO-4 Touch Keyboard Replacement: paso 5, imagen 3 de 3
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. OLPC XO-4 Touch Keyboard Replacement: paso 6, imagen 1 de 2 OLPC XO-4 Touch Keyboard Replacement: paso 6, imagen 2 de 2
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. OLPC XO-4 Touch Keyboard Replacement: paso 7, imagen 1 de 2 OLPC XO-4 Touch Keyboard Replacement: paso 7, imagen 2 de 2
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 3-30, Amido Winter 2013 Miembro de Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 62
Todo El Tiempo: 732
