Introducción
This guide will show you how to access the camera on your OLPC XO 4.0 Touch. The camera records video into your laptop.
Herramientas
Partes
No se especificaron partes.
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
Unplug the ribbon cable from the connector on the underside of the motherboard.
Pull the camera away from the motherboard to remove it.
