Introducción
Fix fuzzy, muffled, or a complete absence of sound with a new set of speakers.
Qué necesitas
Turn the laptop so it is resting on its bottom.
Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
Rotate the top half of the laptop about 90 degrees.
Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets.
Pull the speakers out and feed the cables through their holes in the case.
