Saltar al contenido principal
Nvidia Shield Tablet K1 Back Panel Replacement
Qué necesitas
  1. Nvidia Shield Tablet K1 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 Back Panel Replacement: paso 2, imagen 1 de 2 Nvidia Shield Tablet K1 Back Panel Replacement: paso 2, imagen 2 de 2
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
Conclusión
7 personas más completaron esta guía.
Ryan Butler
Miembro Desde 02/09/16
1,695 Reputación
9 Guías creadas
Equipo
iFixit, Team 1-1, Weber Winter 2016 Miembro de iFixit, Team 1-1, Weber Winter 2016
FIX-WEBER-W16S1G1
4 Miembros
37 Guías creadas
2 comentarios
Hello, I’m planning on replacing the battery on my K1 soon, will the rear panel snap back in?
Scott - Contestar
but wait theres flex cable your not showing thats attached to the cover it could be ripped off and bricked like mine because no one know the name of said cable
Christian Rogers - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 4,917
