Saltar al contenido principal
Nvidia Shield Pro Android TV Motherboard Replacement
Qué necesitas
  1. Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Use a plastic opening tool to pry open the front panel.
  2. Nvidia Shield Pro Android TV Motherboard Replacement: paso 2, imagen 1 de 3 Nvidia Shield Pro Android TV Motherboard Replacement: paso 2, imagen 2 de 3 Nvidia Shield Pro Android TV Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a Torx TR6 screwdriver to remove the five 6mm screws that are securing the fan.
    • Unplug the power supply connected to the fan.
  3. Nvidia Shield Pro Android TV Motherboard Replacement: paso 3, imagen 1 de 2 Nvidia Shield Pro Android TV Motherboard Replacement: paso 3, imagen 2 de 2
    • Unplug the two black cable bundles that are running over the motherboard.
  4. Nvidia Shield Pro Android TV Motherboard Replacement: paso 4, imagen 1 de 3 Nvidia Shield Pro Android TV Motherboard Replacement: paso 4, imagen 2 de 3 Nvidia Shield Pro Android TV Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a Torx TR6 screwdriver to remove the three 5mm screws securing the motherboard.
    • Detach the black and white coaxial cables from the motherboard.
    • Lift the motherboard out of the device and disconnect the black cable bundle.
Conclusión
2 personas más completaron esta guía.
Un comentario
Please update the title of this to specify which model year Shield Pro it is for. I was looking for the 2019 model instructions and this obviously isn't that.
Thanks!
jkr4m3r - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 58
Todo El Tiempo: 2,409
