Saltar al contenido principal
Nvidia Shield Pro Android TV Controller D-Pad Replacement
Qué necesitas
  1. Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: paso 1, imagen 1 de 3 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: paso 1, imagen 2 de 3 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: paso 1, imagen 3 de 3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 2, imagen 1 de 1
    • Gently open the top frame of the cover with the plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 3, imagen 1 de 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 3, imagen 2 de 2
    • Gently pull the wire connector out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 4, imagen 1 de 1
    • Remove the wire attached to the circular piece.
  5. Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 5, imagen 1 de 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 5, imagen 2 de 2
    • Carefully remove the two T6 Torx screws from either side of the motherboard.
  6. Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 6, imagen 1 de 1
    • Remove the yellow plug from its socket.
  7. Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 7, imagen 1 de 2 Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 7, imagen 2 de 2
    • Remove the two T6 Torx screws.
  8. Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 8, imagen 1 de 1
    • Slowly pull up the primary circuit board of the controller until the D-pad is revealed.
    • Carefully remove the board.
  9. Nvidia Shield Pro Android TV Controller D-Pad Replacement: paso 9, imagen 1 de 1
    • Gently remove and replace the D-Pad.
Conclusión
Ben Carrasco
Miembro Desde 01/23/20
332 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G2, White Winter 2020 Miembro de Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 13
Ultimos 30 días: 22
Todo El Tiempo: 1,047
