Saltar al contenido principal
NVIDIA SHIELD Portable Motherboard Replacement
Qué necesitas
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: paso 1, imagen 1 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: paso 1, imagen 2 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: paso 1, imagen 3 de 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: paso 2, imagen 1 de 2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: paso 2, imagen 2 de 2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: paso 3, imagen 1 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: paso 3, imagen 2 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: paso 3, imagen 3 de 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: paso 4, imagen 1 de 1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: paso 5, imagen 1 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: paso 5, imagen 2 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: paso 5, imagen 3 de 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: paso 6, imagen 1 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: paso 6, imagen 2 de 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: paso 6, imagen 3 de 3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
Conclusión
3 personas más completaron esta guía.
Marc Perez
Miembro Desde 09/29/14
545 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Hickman Fall 2014 Miembro de USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Miembros
18 Guías creadas
Un comentario
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,802
