Saltar al contenido principal
Nuvision TM800A510L Headphone Jack Replacement
Qué necesitas
  1. Nuvision TM800A510L Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 2 Nuvision TM800A510L Headphone Jack Replacement, Headphone Jack: paso 1, imagen 2 de 2
    • Use a Heat Gun to loosen the adhesive around the inside of the device.
    • Use prying tools to lift the back of the device up.
    • I recommend prying up one side at a time and heating the adhesive to 'just barely too hot to touch'.
  2. Nuvision TM800A510L Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Unscrew the headphone jack from the device.
  3. Nuvision TM800A510L Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Unlock the headphone jack ribbon.
  4. Nuvision TM800A510L Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Move the wires out of the way and slowly pull the ribbon out of the circuit dock.
  5. Nuvision TM800A510L Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Lift headphone jack/ribbon out and it's FREE!
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 277
