Saltar al contenido principal
Nutribullet Rx #NB-301 Drive Socket Replacement
Qué necesitas
  1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: paso 1, imagen 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: paso 1, imagen 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: paso 1, imagen 3 de 3
    • Make sure to unplug the device before you start the repair.
    • Flip the blender over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
    • Remove the base cover from the blender.
  2. Nutribullet Rx #NB-301 Drive Socket Replacement: paso 2, imagen 1 de 2 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 2, imagen 2 de 2
    • Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
  3. Nutribullet Rx #NB-301 Drive Socket Replacement: paso 3, imagen 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 3, imagen 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 3, imagen 3 de 3
    • Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
    • Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
  4. Nutribullet Rx #NB-301 Drive Socket Replacement: paso 4, imagen 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 4, imagen 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 4, imagen 3 de 3
    • Remove the drive socket from the motor.
  5. Nutribullet Rx #NB-301 Drive Socket Replacement: paso 5, imagen 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 5, imagen 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 5, imagen 3 de 3
    • Remove all dust and residue from the area before you replace your new drive socket.
  6. Nutribullet Rx #NB-301 Drive Socket Replacement: paso 6, imagen 1 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 6, imagen 2 de 3 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 6, imagen 3 de 3
    • Use a Phillips #2 screwdriver to secure the drive socket to the motor.
  7. Nutribullet Rx #NB-301 Drive Socket Replacement: paso 7, imagen 1 de 2 Nutribullet Rx #NB-301 Drive Socket Replacement: paso 7, imagen 2 de 2
    • Place the bottom cover back on the blender.
    • Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
Conclusión
Martin G
Miembro Desde 03/05/24
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 15
Ultimos 30 días: 29
Todo El Tiempo: 45
