Saltar al contenido principal
Nutri Ninja Ninja Blender Duo BL641 Blade Replacement
Qué necesitas
  1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: paso 1, imagen 1 de 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: paso 1, imagen 2 de 2
    • Make sure blender is turned off.
    • Lift open the lid of blender by pressing the "Release" button and move to the side
  2. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: paso 2, imagen 1 de 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: paso 2, imagen 2 de 2
    • Carefully Grab the top of the blade and pull upward with medium force.
    • The blade should slide out easily.
    • Do not touch the blades! Even when dull they can still cut you.
  3. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: paso 3, imagen 1 de 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: paso 3, imagen 2 de 2
    • Carefully pick up the new blade and match the bottom star shaped opening to the star shaped protrusion from the blender.
  4. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: paso 4, imagen 1 de 1
    • Slowly connect the two star shapes together and push down until it reaches the bottom.
Conclusión
Now your blender can resume blending to perfection.
Charlotte
Miembro Desde 09/26/17
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S7-G1, Banghart Fall 2017 Miembro de Cal Poly, Team S7-G1, Banghart Fall 2017
CPSU-BANGHART-F17S7G1
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 21
Todo El Tiempo: 3,088
