Saltar al contenido principal
Nutri Ninja BL450 Cooling Vent Replacement
Qué necesitas
  1. Nutri Ninja BL450 Cooling Vent Replacement, Small Rubber Wheel: paso 1, imagen 1 de 1
    • Remove the cup from the blender base.
  2. Nutri Ninja BL450 Cooling Vent Replacement: paso 2, imagen 1 de 2 Nutri Ninja BL450 Cooling Vent Replacement: paso 2, imagen 2 de 2
    • Turn the blender over and unscrew the three 14 mm screws holding the slotted base in place. These are Torx Security bits (TR9) on some units.
  3. Nutri Ninja BL450 Cooling Vent Replacement: paso 3, imagen 1 de 3 Nutri Ninja BL450 Cooling Vent Replacement: paso 3, imagen 2 de 3 Nutri Ninja BL450 Cooling Vent Replacement: paso 3, imagen 3 de 3
    • Using a the standard Phillips head screwdriver bit, remove the slotted black plastic covering and then unscrew the one 11mm screw holding the power cord in place.
    • Unscrew the four 14 mm screws that are in the deep slots. This will release the motor from the base.
  4. Nutri Ninja BL450 Cooling Vent Replacement: paso 4, imagen 1 de 3 Nutri Ninja BL450 Cooling Vent Replacement: paso 4, imagen 2 de 3 Nutri Ninja BL450 Cooling Vent Replacement: paso 4, imagen 3 de 3
    • CAUTION: the silver blade attached to the motor is very sharp. Use a towel or thick cloth to protect your hands for the next step.
    • Using a towel, hold the silver fan still. Twist the small black rubber wheel that is attached to the top of the blender base to the right. This will remove the wheel for replacement.
  5. Nutri Ninja BL450 Cooling Vent Replacement, Cooling Vent: paso 5, imagen 1 de 2 Nutri Ninja BL450 Cooling Vent Replacement, Cooling Vent: paso 5, imagen 2 de 2
    • Slide the cooling vent out from the silver plastic part of the blender base and replace it.
Conclusión
Morgan Blauth
Miembro Desde 02/24/16
759 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-5, Leahy Spring 2016 Miembro de USF Tampa, Team 1-5, Leahy Spring 2016
USFT-LEAHY-S16S1G5
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,399
