Introducción
Replace the screen in your Nurian R9 with this guide. Requires teardown and reassembly of device.
Qué necesitas
Locate battery door on the back of the device. Push the switch underneath the door to the unlock position. Remove battery door and batteries.
Use spudger (black tool) to remove black plastic back of the device. Take care when removing the back of the device. The plastic tabs under the back are fragile and may break while prying with the spudger.
Take care not lose the lock/unlock switch as it is freed from the back of the device. (This is the same switch you used to open the battery door in step 1; it's marked in pink in the second photo).
Fit the replacement screen into the black frame.
The ribbon should lay on the same side as the hinge.
Make sure the screw holes in the circuit board line up with screw holes in the black frame.
Fasten the screen and circuit board to the black frame with the four silver screws.
Be careful not to lose these screws when screwing them back in. They are very small and hard to handle.
Fit ribbon back into the hinge slot as shown in the first photo.
Insert the cover's plastic teeth (shown in the second photo) into the slot in the hinge.
Fasten the cover to the the rest of the screen frame with the four silver screws (two on each side).
Be careful because, again, the screws are very small.
