Saltar al contenido principal
Nuphy Air75 Keyboard Switch Replacement
Qué necesitas
  1. Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: paso 1, imagen 1 de 2 Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: paso 1, imagen 2 de 2
    • Place your keyboard on a clean, well-lit surface.
    • Slide the keyboard power switch to the "off" position.
  2. Nuphy Air75 Keyboard Switch Replacement: paso 2, imagen 1 de 3 Nuphy Air75 Keyboard Switch Replacement: paso 2, imagen 2 de 3 Nuphy Air75 Keyboard Switch Replacement: paso 2, imagen 3 de 3
    • Find the wire side of the keycap puller. Slide each wire around opposite sides of the key you are replacing.
    • Pull gently until the key cap comes off.
    • Pull the keycap straight up. This will prevent damage to adjacent keycaps.
  3. Nuphy Air75 Keyboard Switch Replacement: paso 3, imagen 1 de 3 Nuphy Air75 Keyboard Switch Replacement: paso 3, imagen 2 de 3 Nuphy Air75 Keyboard Switch Replacement: paso 3, imagen 3 de 3
    • Use the other side of the switch puller, with two large metal prongs. Fit the prongs onto either side of the switch.
    • Pull the switch out using a side-to-side motion. When one side of the switch lifts up with an audible click, gently lift the other side to fully remove the switch.
    • Do not rock side-to-side into other keys. You can damage adjacent keycaps and the keyboard itself.
  4. Nuphy Air75 Keyboard Switch Replacement: paso 4, imagen 1 de 2 Nuphy Air75 Keyboard Switch Replacement: paso 4, imagen 2 de 2
    • Orient the replacement switch so that the colored, circular module is facing up.
    • Gently press down until you hear an audible click.
    • Place the keycap over the newly installed switch and gently press down.
  5. Nuphy Air75 Keyboard Switch Replacement: paso 5, imagen 1 de 2 Nuphy Air75 Keyboard Switch Replacement: paso 5, imagen 2 de 2
    • Turn the power switch to the "wired" or "wireless" position depending on your setup.
    • Test your keyboard and new key switch.
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 98
Todo El Tiempo: 170
