Saltar al contenido principal
Numark TT1600 Belt Drive Replacement
  1. Numark TT1600 Belt Drive Replacement, Belt Drive: paso 1, imagen 1 de 1
    • Remove slip mat from top of the platter.
  2. Numark TT1600 Belt Drive Replacement: paso 2, imagen 1 de 1
    • Remove platter by inserting thumbs in holes and slowly pulling up.
    • There will be some initial resistance.
  3. Numark TT1600 Belt Drive Replacement: paso 3, imagen 1 de 1
    • Remove damaged belt which will be located below the platter.
  4. Numark TT1600 Belt Drive Replacement: paso 4, imagen 1 de 1
    • Install new belt by securing it around the inner ring, located on the back of the platter.
  5. Numark TT1600 Belt Drive Replacement: paso 5, imagen 1 de 1
    • Place a thumb in each hole.
    • You should be able to feel the rubber belt.
    • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
  6. Numark TT1600 Belt Drive Replacement: paso 6, imagen 1 de 2 Numark TT1600 Belt Drive Replacement: paso 6, imagen 2 de 2
    • Secure platter back on turntable while keeping belt taut.
    • Pull belt around motor spindle.
    • Gently let go of belt.
  7. Numark TT1600 Belt Drive Replacement: paso 7, imagen 1 de 1
    • Test turntable by spinning the platter.
    • There should be slight tension causing the platter to come to a stop.
Linea de Meta
2 personas más completaron esta guía.
Nikolai
Miembro Desde 10/12/11
254 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-14, Regan Fall 2011 Miembro de Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 45
Todo El Tiempo: 6,292
