Saltar al contenido principal
Numark TT1600 Audio Jacks Replacement
Qué necesitas
  1. Numark TT1600 Audio Jacks Replacement, Audio Jacks: paso 1, imagen 1 de 1
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Numark TT1600 Audio Jacks Replacement: paso 2, imagen 1 de 2 Numark TT1600 Audio Jacks Replacement: paso 2, imagen 2 de 2
    • Find the audio jacks located on the back side of the turntable.
    • Remove the screw located in between the right and left audio jacks.
  3. Numark TT1600 Audio Jacks Replacement: paso 3, imagen 1 de 1
    • Remove the back cover by pulling it apart.
  4. Numark TT1600 Audio Jacks Replacement: paso 4, imagen 1 de 1
    • Remove the grounding hardware located next to the audio jacks.
  5. Numark TT1600 Audio Jacks Replacement: paso 5, imagen 1 de 2 Numark TT1600 Audio Jacks Replacement: paso 5, imagen 2 de 2
    • Remove the ground screw and washers.
  6. Numark TT1600 Audio Jacks Replacement: paso 6, imagen 1 de 1
    • Remove the remaining nut and washer.
  7. Numark TT1600 Audio Jacks Replacement: paso 7, imagen 1 de 1
    • Remove the screw located on the back panel of the audio jack housing.
  8. Numark TT1600 Audio Jacks Replacement: paso 8, imagen 1 de 3 Numark TT1600 Audio Jacks Replacement: paso 8, imagen 2 de 3 Numark TT1600 Audio Jacks Replacement: paso 8, imagen 3 de 3
    • Remove the screw that connects the audio jacks to the biggest circuit board via wire.
  9. Numark TT1600 Audio Jacks Replacement: paso 9, imagen 1 de 1
    • Gently pull out the audio input jacks from the audio input housing.
Conclusión
Una persona más ha completado esta guía.
Nikolai
Miembro Desde 10/12/11
254 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-14, Regan Fall 2011 Miembro de Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,380
