Saltar al contenido principal
Numark N4 Effect button cover Replacement
Qué necesitas
  1. Numark N4 Effect button cover Replacement, Numark N4 Disassembly: paso 1, imagen 1 de 1
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 Effect button cover Replacement: paso 2, imagen 1 de 1
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 Effect button cover Replacement: paso 3, imagen 1 de 1
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 Effect button cover Replacement: paso 4, imagen 1 de 1
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 Effect button cover Replacement: paso 5, imagen 1 de 1
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 Effect button cover Replacement: paso 6, imagen 1 de 1
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 Effect button cover Replacement, Effect button cover: paso 7, imagen 1 de 1
    • Locate the top right PCB circuit board.
  8. Numark N4 Effect button cover Replacement: paso 8, imagen 1 de 1
    • Unplug the two ribbon cables as shown.
  9. Numark N4 Effect button cover Replacement: paso 9, imagen 1 de 1
    • Loosen and remove the 11 12mm screws from the circuit board using Phillips #2 screwdriver.
  10. Numark N4 Effect button cover Replacement: paso 10, imagen 1 de 1
    • Carefully remove the circuit board from its housing.
  11. Numark N4 Effect button cover Replacement: paso 11, imagen 1 de 1
    • Carefully remove the plastic button covers as depicted.
Conclusión
2 personas más completaron esta guía.
Erik Charlton
Miembro Desde 10/10/17
789 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S13-G11, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 466
