Saltar al contenido principal
Numark N4 BP Main PCB Board Replacement
Qué necesitas
  1. Numark N4 BP Main PCB Board Replacement, Numark N4 Disassembly: paso 1, imagen 1 de 1
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 BP Main PCB Board Replacement: paso 2, imagen 1 de 1
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 BP Main PCB Board Replacement: paso 3, imagen 1 de 1
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 BP Main PCB Board Replacement: paso 4, imagen 1 de 1
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 BP Main PCB Board Replacement: paso 5, imagen 1 de 1
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 BP Main PCB Board Replacement: paso 6, imagen 1 de 1
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 BP Main PCB Board Replacement, Numark N4 BP Main PCB Board: paso 7, imagen 1 de 1
    • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
  8. Numark N4 BP Main PCB Board Replacement: paso 8, imagen 1 de 1
    • Carefully remove the circuit board from its housing.
Conclusión
3 personas más completaron esta guía.
Erik Charlton
Miembro Desde 10/10/17
873 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S13-G11, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
Miembros de 4
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 1,610
