Saltar al contenido principal
NuVision TM1088 Motherboard Replacement
Qué necesitas
  1. NuVision TM1088 Motherboard Replacement, Rear Cover: paso 1, imagen 1 de 1
    • Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
  2. NuVision TM1088 Motherboard Replacement, Motherboard: paso 2, imagen 1 de 1
    • Remove the two plugs for the screen by pulling up and away from the motherboard.
  3. NuVision TM1088 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the plug for the cameras by pulling the plug up and away from the motherboard.
  4. NuVision TM1088 Motherboard Replacement: paso 4, imagen 1 de 1
    • Melt solder and remove red and black wires leading to the battery.
  5. NuVision TM1088 Motherboard Replacement: paso 5, imagen 1 de 1
    • Melt the solder on the black and gray wires and remove wires from motherboard.
  6. NuVision TM1088 Motherboard Replacement: paso 6, imagen 1 de 1
    • Melt the solder and remove the red and black wires leading to the speaker.
  7. NuVision TM1088 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the four 4 mm Phillips head screws holding in the motherboard.
  8. NuVision TM1088 Motherboard Replacement: paso 8, imagen 1 de 1
    • Lift the motherboard away from the front cover assembly.
Conclusión
Una persona más ha completado esta guía.
Nathaniel Nasman
Miembro Desde 03/23/15
750 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Miles Spring 2015 Miembro de UMass Dartmouth, Team 1-1, Miles Spring 2015
UMASSD-MILES-S15S1G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 1,661
