Saltar al contenido principal
NuVision 10.1 Atom Battery Replacement
Qué necesitas
  1. NuVision 10.1 Atom Battery Replacement, Camera: paso 1, imagen 1 de 3 NuVision 10.1 Atom Battery Replacement, Camera: paso 1, imagen 2 de 3 NuVision 10.1 Atom Battery Replacement, Camera: paso 1, imagen 3 de 3
    • Turn the device screen side down.
    • Carefully remove the back piece with the iFixit opening tool.
  2. NuVision 10.1 Atom Battery Replacement: paso 2, imagen 1 de 1
    • Remove the yellow tape covering the motherboard gently with your fingers.
  3. NuVision 10.1 Atom Battery Replacement: paso 3, imagen 1 de 3 NuVision 10.1 Atom Battery Replacement: paso 3, imagen 2 de 3 NuVision 10.1 Atom Battery Replacement: paso 3, imagen 3 de 3
    • Pull the camera plug upward and away from the motherboard with your fingers.
    • Gently pull the camera from the device. The camera is held by tension.
  4. NuVision 10.1 Atom Battery Replacement, Speaker: paso 4, imagen 1 de 1
    • Carefully remove silver tape with your fingers.
  5. NuVision 10.1 Atom Battery Replacement: paso 5, imagen 1 de 2 NuVision 10.1 Atom Battery Replacement: paso 5, imagen 2 de 2
    • Remove speakers gently using your fingers, they pop out easily.
    • Disconnect cords attached to the speaker from white pod.
  6. NuVision 10.1 Atom Battery Replacement, Motherboard: paso 6, imagen 1 de 1
    • Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
  7. NuVision 10.1 Atom Battery Replacement: paso 7, imagen 1 de 3 NuVision 10.1 Atom Battery Replacement: paso 7, imagen 2 de 3 NuVision 10.1 Atom Battery Replacement: paso 7, imagen 3 de 3
    • Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
    • Be careful not to puncture the battery.
  8. NuVision 10.1 Atom Battery Replacement: paso 8, imagen 1 de 2 NuVision 10.1 Atom Battery Replacement: paso 8, imagen 2 de 2
    • Disconnect the battery's bundled cable connector from the motherboard with fingers.
  9. NuVision 10.1 Atom Battery Replacement: paso 9, imagen 1 de 3 NuVision 10.1 Atom Battery Replacement: paso 9, imagen 2 de 3 NuVision 10.1 Atom Battery Replacement: paso 9, imagen 3 de 3
    • Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
  10. NuVision 10.1 Atom Battery Replacement, Battery: paso 10, imagen 1 de 3 NuVision 10.1 Atom Battery Replacement, Battery: paso 10, imagen 2 de 3 NuVision 10.1 Atom Battery Replacement, Battery: paso 10, imagen 3 de 3
    • Pry the battery away from the display screen gently using a nylon spudger or the plastic opening tools.
    • Using a metal spudger may bend or puncture the battery. Lithium batteries are prone to explode.
    • There is a lot of adhesive, take your time and be careful.
Conclusión
Carly Daniele
Miembro Desde 02/14/19
567 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G5, Leahy Spring 2019 Miembro de USF Tampa, Team S1-G5, Leahy Spring 2019
USFT-LEAHY-S19S1G5
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 894
