Saltar al contenido principal
Novatel MiFi 2200 Case Replacement
Qué necesitas
  1. Novatel MiFi 2200 Case Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: paso 2, imagen 1 de 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: paso 3, imagen 1 de 1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: paso 4, imagen 1 de 1
    • Once the seal has been broken all the way around, open the cases using your hands.
Conclusión
2 personas más completaron esta guía.
Justin Russo
Miembro Desde 04/15/12
196 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-36, Maness Spring 2012 Miembro de Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Miembros
5 Guías creadas
Un comentario
If case gets damaged, is there a place to but the case
Snehraj Merchant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,541
