Saltar al contenido principal
Novatel MiFi 2 4G LTE Hotspot SIM Card Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: paso 1, imagen 1 de 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: paso 1, imagen 2 de 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: paso 1, imagen 3 de 3
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Place your thumb under the latch of the black plastic battery cover as shown.
    • Remove the battery cover. This will require some force.
  2. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery: paso 2, imagen 1 de 2 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery: paso 2, imagen 2 de 2
    • Gently place your thumb on the right side of the battery as shown.
    • Remove the battery from its socket by lifting it up and out.
  3. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: paso 3, imagen 1 de 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: paso 3, imagen 2 de 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: paso 3, imagen 3 de 3
    • Once the battery has been removed, the SIM Card slot can be accessed.
    • Carefully take out the dead SIM Card by lifting it from its position with your fingers.
Conclusión
GerardFoley
Miembro Desde 10/08/18
351 Reputación
4 Guías creadas
Equipo
Marist, Team S1-G5, Chaterdon Fall 2018 Miembro de Marist, Team S1-G5, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G5
3 Miembros
4 Guías creadas
Un comentario
What kind of SIM card do I need for this?
Abner - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 766
