Saltar al contenido principal
Nostalgia GCM200 Heating Bowl Replacement
Qué necesitas
  1. Nostalgia GCM200 Heating Bowl  Replacement, Nostalgia GCM200 Disassembly: paso 1, imagen 1 de 2 Nostalgia GCM200 Heating Bowl  Replacement, Nostalgia GCM200 Disassembly: paso 1, imagen 2 de 2
    • Remove the two 1.3 mm Phillips #2 screws.
    • Remove the S6 spanner screw.
    • Carefully place these three screws somewhere safe to use later in reassembly.
  2. Nostalgia GCM200 Heating Bowl  Replacement: paso 2, imagen 1 de 1
    • Split the device in half to expose the internal parts of the device.
    • Again, there are two more Phillips screws to remove.
  3. Nostalgia GCM200 Heating Bowl  Replacement: paso 3, imagen 1 de 1
    • Remove the two screws from both sides of the heating coil.
  4. Nostalgia GCM200 Heating Bowl  Replacement, Heating Bowl: paso 4, imagen 1 de 1
    • Remove the heating bowl from the plastic housing.
Conclusión
Follow the instruction and you will know how to replace the bowl for this device
3 personas más completaron esta guía.
Xingdi Zhou
Miembro Desde 06/27/17
466 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S1-G4, Liner Summer 2017 Miembro de UW Tacoma, Team S1-G4, Liner Summer 2017
UWT-LINER-SU17S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 155
