Saltar al contenido principal
Nostalgia Electrics RHP-310 Motor Replacement
Qué necesitas
  1. Nostalgia Electrics RHP-310 Motor Replacement, Power Switch: paso 1, imagen 1 de 1
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Motor Replacement: paso 2, imagen 1 de 1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Motor Replacement: paso 3, imagen 1 de 1
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Motor Replacement: paso 4, imagen 1 de 2 Nostalgia Electrics RHP-310 Motor Replacement: paso 4, imagen 2 de 2
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Motor Replacement: paso 5, imagen 1 de 1
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Motor Replacement: paso 6, imagen 1 de 1
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
  7. Nostalgia Electrics RHP-310 Motor Replacement, Replacing Housing: paso 7, imagen 1 de 2 Nostalgia Electrics RHP-310 Motor Replacement, Replacing Housing: paso 7, imagen 2 de 2
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Save the screws from this step. You will need them to connect the new housing to the white top.
  8. Nostalgia Electrics RHP-310 Motor Replacement: paso 8, imagen 1 de 1
    • Remove the white top from the housing.
  9. Nostalgia Electrics RHP-310 Motor Replacement, Replacing Fan: paso 9, imagen 1 de 1
    • Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
    • Keep the screws in a safe place. You will need them to put the heating component back together.
  10. Nostalgia Electrics RHP-310 Motor Replacement: paso 10, imagen 1 de 1
    • Pull the heating component apart.
  11. Nostalgia Electrics RHP-310 Motor Replacement: paso 11, imagen 1 de 2 Nostalgia Electrics RHP-310 Motor Replacement: paso 11, imagen 2 de 2
    • Locate the fan.
    • Pull the fan off the motor.
    • Do not pull too hard or you will break the motor.
  12. Nostalgia Electrics RHP-310 Motor Replacement: paso 12, imagen 1 de 1
    • You can now replace the fan. If there is debris, clean it out.
  13. Nostalgia Electrics RHP-310 Motor Replacement, Motor: paso 13, imagen 1 de 2 Nostalgia Electrics RHP-310 Motor Replacement, Motor: paso 13, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 2.5mm screws connecting the motor to the fan base.
    • Remember to keep the screws. You will need them to reassemble the popper.
    • Remove the motor from the fan base.
  14. Nostalgia Electrics RHP-310 Motor Replacement: paso 14, imagen 1 de 1
    • Un-solder the wires that are connected to the motor.
  15. Nostalgia Electrics RHP-310 Motor Replacement: paso 15, imagen 1 de 1
    • Replace the old motor by soldering the new motor to the circuit board.
Conclusión
Dana Clarke
Miembro Desde 09/26/12
50 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 16-57, Forte Fall 2012 Miembro de Cal Poly, Team 16-57, Forte Fall 2012
CPSU-FORTE-F12S16G57
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,920
