Saltar al contenido principal
Nostalgia Electrics PCM805 Power Switch Replacement
Qué necesitas
  1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: paso 1, imagen 1 de 2 Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: paso 1, imagen 2 de 2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Power Switch Replacement: paso 2, imagen 1 de 1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: paso 3, imagen 1 de 1
    • Locate the switch/wire assembly inside the device.
  4. Nostalgia Electrics PCM805 Power Switch Replacement: paso 4, imagen 1 de 1
    • Pull back the insulation sleeves to expose the connector heads.
  5. Nostalgia Electrics PCM805 Power Switch Replacement: paso 5, imagen 1 de 2 Nostalgia Electrics PCM805 Power Switch Replacement: paso 5, imagen 2 de 2
    • Note the color of each wire and the order you remove them.
    • Using a pair of pliers, firmly grip the base of the wire.
    • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
    • Pull the wire straight out of the switch.
    • Repeat this step for each wire.
  6. Nostalgia Electrics PCM805 Power Switch Replacement: paso 6, imagen 1 de 2 Nostalgia Electrics PCM805 Power Switch Replacement: paso 6, imagen 2 de 2
    • Using pliers, pinch tabs at the top and bottom of switch.
    • While pinching the tabs, push the switch until the tabs are on the outside of the device.
  7. Nostalgia Electrics PCM805 Power Switch Replacement: paso 7, imagen 1 de 2 Nostalgia Electrics PCM805 Power Switch Replacement: paso 7, imagen 2 de 2
    • Remove the switch from the device.
Conclusión
Carlton
Miembro Desde 01/13/15
672 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 3-5, Hickman Winter 2015 Miembro de USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Miembros
8 Guías creadas
Un comentario
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 1,982
