Saltar al contenido principal
Nostalgia Electrics PCM805 Motor Replacement
Qué necesitas
  1. Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: paso 1, imagen 1 de 2 Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: paso 1, imagen 2 de 2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Motor Replacement: paso 2, imagen 1 de 1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: paso 3, imagen 1 de 2 Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: paso 3, imagen 2 de 2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  4. Nostalgia Electrics PCM805 Motor Replacement: paso 4, imagen 1 de 3 Nostalgia Electrics PCM805 Motor Replacement: paso 4, imagen 2 de 3 Nostalgia Electrics PCM805 Motor Replacement: paso 4, imagen 3 de 3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  5. Nostalgia Electrics PCM805 Motor Replacement, Motor: paso 5, imagen 1 de 2 Nostalgia Electrics PCM805 Motor Replacement, Motor: paso 5, imagen 2 de 2
    • Remove the four 12mm Phillips #02 screws to free the motor housing.
  6. Nostalgia Electrics PCM805 Motor Replacement: paso 6, imagen 1 de 2 Nostalgia Electrics PCM805 Motor Replacement: paso 6, imagen 2 de 2
    • Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out.
Conclusión
Equipo
USF Tampa, Team 3-5, Hickman Winter 2015 Miembro de USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Miembros
8 Guías creadas
2 comentarios
Hello.
I purchased this item in a red variation from VAT19. It does not work but the light comes on. I live in the UK and we have a higher Voltage(240V) running in our domestic supply.
Something may have blown.
Can you advise what is it likely to be?
If there is a part that we can replace, can you advise which one and where I can purchase it from please?
Moh - Contestar
Hi, I need the cotton machine from the nostalgia cotton sugar machine and I don't know where to get it. can you help me? My email is terebcn18@hotmail.com
Teresa gb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 35
Todo El Tiempo: 3,139
