Qué necesitas
Use your hands to lift up the auger (the long black metal spiral) away from the base bowl.
Flip over the device so that the bowl is now face down.
Use your hands to unscrew both 21.3mm screws.
Unscrew the two 22.1 mm machine screws that secure the motor with a Phillips #2 screwdriver.
Remove their adjoining 5.9 mm washers by hand.
Casi Terminas!
Conclusión
