Saltar al contenido principal
Nortel Networks i2004 IP Speaker Replacement
Qué necesitas
  1. Nortel Networks i2004 IP Speaker Replacement, Back Cover: paso 1, imagen 1 de 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: paso 1, imagen 2 de 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: paso 1, imagen 3 de 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Speaker Replacement: paso 3, imagen 1 de 2 Nortel Networks i2004 IP Speaker Replacement: paso 3, imagen 2 de 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Speaker Replacement: paso 4, imagen 1 de 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Speaker Replacement: paso 5, imagen 1 de 2 Nortel Networks i2004 IP Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Speaker Replacement, Speaker: paso 6, imagen 1 de 1
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  7. Nortel Networks i2004 IP Speaker Replacement: paso 7, imagen 1 de 1
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  8. Nortel Networks i2004 IP Speaker Replacement: paso 8, imagen 1 de 2 Nortel Networks i2004 IP Speaker Replacement: paso 8, imagen 2 de 2
    • Solder wires to new speaker.
Conclusión
Una persona más ha completado esta guía.
Elizabeth
Miembro Desde 01/21/12
160 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-35, Amido Winter 2012 Miembro de Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,122
