Saltar al contenido principal
Nortel Networks i2004 IP Buttons Replacement
Qué necesitas
  1. Nortel Networks i2004 IP Buttons Replacement, Back Cover: paso 1, imagen 1 de 3 Nortel Networks i2004 IP Buttons Replacement, Back Cover: paso 1, imagen 2 de 3 Nortel Networks i2004 IP Buttons Replacement, Back Cover: paso 1, imagen 3 de 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Buttons Replacement: paso 3, imagen 1 de 2 Nortel Networks i2004 IP Buttons Replacement: paso 3, imagen 2 de 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Buttons Replacement: paso 4, imagen 1 de 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Buttons Replacement: paso 5, imagen 1 de 2 Nortel Networks i2004 IP Buttons Replacement: paso 5, imagen 2 de 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Buttons Replacement, Circuit Board: paso 6, imagen 1 de 1
    • Remove the red and white wires from the rubber casing rim.
  7. Nortel Networks i2004 IP Buttons Replacement: paso 7, imagen 1 de 2 Nortel Networks i2004 IP Buttons Replacement: paso 7, imagen 2 de 2
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
  8. Nortel Networks i2004 IP Buttons Replacement: paso 8, imagen 1 de 1
    • Remove the two 8mm Phillips #2 screws.
  9. Nortel Networks i2004 IP Buttons Replacement: paso 9, imagen 1 de 2 Nortel Networks i2004 IP Buttons Replacement: paso 9, imagen 2 de 2
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
  10. Nortel Networks i2004 IP Buttons Replacement: paso 10, imagen 1 de 3 Nortel Networks i2004 IP Buttons Replacement: paso 10, imagen 2 de 3 Nortel Networks i2004 IP Buttons Replacement: paso 10, imagen 3 de 3
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
  11. Nortel Networks i2004 IP Buttons Replacement: paso 11, imagen 1 de 2 Nortel Networks i2004 IP Buttons Replacement: paso 11, imagen 2 de 2
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
  12. Nortel Networks i2004 IP Buttons Replacement: paso 12, imagen 1 de 1
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
  13. Nortel Networks i2004 IP Buttons Replacement: paso 13, imagen 1 de 1
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
  14. Nortel Networks i2004 IP Buttons Replacement, Buttons: paso 14, imagen 1 de 1
    • Press the broken button from the front of the phone.
    • Remove the broken button through the back.
Conclusión
Una persona más ha completado esta guía.
Andrew Wang
Miembro Desde 01/19/12
9 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-35, Amido Winter 2012 Miembro de Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 1,055
