Introducción
This guide will show you how to remove and replace the battery of your Nook Tablet.
Herramientas
Partes
No se especificaron partes.
Lift up the foam pad at the corner of the battery to reveal the battery connector.
Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
Lift up the foam that covers the power connector and volume connector.
Disconnect the power and volume cables from their sockets on the motherboard.
Set aside the motherboard and focus on the metal backing containing the battery.
It is not necessary to remove the battery to replace the display. Move on to Step 11.
Use the screwdriver or plastic prying tool around the edges of the battery to pry it from its slot in the metal backing.
Pick up the battery and remove it making sure to free the cords in the upper left hand corner by sliding it out rather than lifting it.
13 personas más completaron esta guía.
2 comentarios
How does one disconnect the battery connection in Step 8? The photo shows it miraculously disconnected and the head of a flathead screwdriver is visible, but it doesn't show how to actually remove that connector which has some sort of interlock. Do you just pry the connector away or do you pry it up? The new battery connector has the same interlock, but gives no clue as to how one would make or remove the connector.
