Saltar al contenido principal
Nook HD Speakers Replacement
Qué necesitas
  1. Nook HD Speakers Replacement, Case: paso 1, imagen 1 de 3 Nook HD Speakers Replacement, Case: paso 1, imagen 2 de 3 Nook HD Speakers Replacement, Case: paso 1, imagen 3 de 3
    • Be sure the device is powered off. Clean the device to prevent any dirt and dust from entering into the device.
    • Use the plastic opening tool to gently pry the plastic screen frame away from the screen. Run the plastic opening tool along the interior edge of the screen until the screen frame is completely separated from the glass.
    • The screen frame is held onto the Nook by a set of tab that run around the outside of the frame. There may also be a line of rubber cement around the Nook under the screen frame. If your Nook has this, you will have to dig deep to separate the frame from the Nook.
  2. Nook HD Speakers Replacement: paso 2, imagen 1 de 2 Nook HD Speakers Replacement: paso 2, imagen 2 de 2
    • Use a T5 screwdriver to remove the seventeen 5.0 millimeter screws from the back casing.
  3. Nook HD Speakers Replacement: paso 3, imagen 1 de 3 Nook HD Speakers Replacement: paso 3, imagen 2 de 3 Nook HD Speakers Replacement: paso 3, imagen 3 de 3
    • Slowly pull the back casing away from the screen and motherboard.
    • There is a cable attaching the battery in the back plate to the motherboard. Avoid detaching either end of the cable during this step.
  4. Nook HD Speakers Replacement: paso 4, imagen 1 de 3 Nook HD Speakers Replacement: paso 4, imagen 2 de 3 Nook HD Speakers Replacement: paso 4, imagen 3 de 3
    • Use the plastic opening tool to gently unclip the wire from the pins by pulling the white connector up.
  5. Nook HD Speakers Replacement, Speakers: paso 5, imagen 1 de 2 Nook HD Speakers Replacement, Speakers: paso 5, imagen 2 de 2
    • Use the plastic opening tool to pry the speakers away from the back plate starting with the inside edge. The speakers are likely glued to the backplate so some resistance is expected.
    • Place the replacement speakers so that they line up properly with the circuit board in order to make a connection.
Conclusión
3 personas más completaron esta guía.
Connor Pickert
Miembro Desde 04/17/14
320 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-43, Maness Spring 2014 Miembro de Cal Poly, Team 3-43, Maness Spring 2014
CPSU-MANESS-S14S3G43
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 825
