Saltar al contenido principal
Nook HD+ Battery Replacement
Qué necesitas
  1. Nook HD+ Battery Replacement, Remove the front frame: paso 1, imagen 1 de 3 Nook HD+ Battery Replacement, Remove the front frame: paso 1, imagen 2 de 3 Nook HD+ Battery Replacement, Remove the front frame: paso 1, imagen 3 de 3
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Nook HD+ Battery Replacement, Remove the screws: paso 2, imagen 1 de 2 Nook HD+ Battery Replacement, Remove the screws: paso 2, imagen 2 de 2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Battery Replacement, Remove the chassis: paso 3, imagen 1 de 1
    • Carefully remove center chassis from bottom frame.
  4. Nook HD+ Battery Replacement, Detach battery: paso 4, imagen 1 de 3 Nook HD+ Battery Replacement, Detach battery: paso 4, imagen 2 de 3 Nook HD+ Battery Replacement, Detach battery: paso 4, imagen 3 de 3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Battery Replacement, Remove the battery: paso 5, imagen 1 de 2 Nook HD+ Battery Replacement, Remove the battery: paso 5, imagen 2 de 2
    • Pry battery off of bottom frame using plastic opening tool.
  6. Nook HD+ Battery Replacement, Place new battery: paso 6, imagen 1 de 1
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
Conclusión
12 personas más completaron esta guía.
Elijah Gonsalves
Miembro Desde 10/24/14
1,049 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Miembros
10 Guías creadas
6 comentarios
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Contestar
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Contestar
Anyone have a lead on good batteries?
omarhani - Contestar
clear directions, liked this guide
wandat100 - Contestar
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 53
Todo El Tiempo: 9,576
