Saltar al contenido principal
Nook HD+ Antenna Replacement
Qué necesitas
  1. Nook HD+ Antenna Replacement, Antenna: paso 1, imagen 1 de 1
    • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  2. Nook HD+ Antenna Replacement, Remove the screws: paso 2, imagen 1 de 2 Nook HD+ Antenna Replacement, Remove the screws: paso 2, imagen 2 de 2
    • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Antenna Replacement, Remove the chassis: paso 3, imagen 1 de 2 Nook HD+ Antenna Replacement, Remove the chassis: paso 3, imagen 2 de 2
    • Carefully remove the center chassis from the bottom frame.
  4. Nook HD+ Antenna Replacement, Dettatch battery: paso 4, imagen 1 de 3 Nook HD+ Antenna Replacement, Dettatch battery: paso 4, imagen 2 de 3 Nook HD+ Antenna Replacement, Dettatch battery: paso 4, imagen 3 de 3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Antenna Replacement, Flip the center chassis: paso 5, imagen 1 de 1
    • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
  6. Nook HD+ Antenna Replacement, Remove the antenna part 1: paso 6, imagen 1 de 2 Nook HD+ Antenna Replacement, Remove the antenna part 1: paso 6, imagen 2 de 2
    • Remove the wire from the attachment on the motherboard (this wire un-clips).
  7. Nook HD+ Antenna Replacement, Remove the antenna part 2: paso 7, imagen 1 de 2 Nook HD+ Antenna Replacement, Remove the antenna part 2: paso 7, imagen 2 de 2
    • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
  8. Nook HD+ Antenna Replacement, Place new antenna.: paso 8, imagen 1 de 2 Nook HD+ Antenna Replacement, Place new antenna.: paso 8, imagen 2 de 2
    • Replace new antenna following all the steps in reverse.
Conclusión
Una persona más ha completado esta guía.
Elijah Gonsalves
Miembro Desde 10/24/14
1,049 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,128
