Saltar al contenido principal
Nook Color Motherboard Replacement
Qué necesitas
  1. Nook Color Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Nook Color Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Motherboard Replacement: paso 2, imagen 1 de 2 Nook Color Motherboard Replacement: paso 2, imagen 2 de 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Motherboard Replacement, Front Cover: paso 3, imagen 1 de 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Motherboard Replacement: paso 4, imagen 1 de 2 Nook Color Motherboard Replacement: paso 4, imagen 2 de 2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Motherboard Replacement: paso 5, imagen 1 de 2 Nook Color Motherboard Replacement: paso 5, imagen 2 de 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 Nook Color Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 Nook Color Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
  7. Nook Color Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
  8. Nook Color Motherboard Replacement: paso 8, imagen 1 de 2 Nook Color Motherboard Replacement: paso 8, imagen 2 de 2
    • Lift the motherboard gently from the side with the larger connector ribbon.
    • Slide the white cable gently from underneath its holding place to free the motherboard completely.
    • Remove the motherboard carefully from the device.
Conclusión
2 personas más completaron esta guía.
Matthew Perdomo
Miembro Desde 01/20/15
497 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 11-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,078
