Qué necesitas
Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
2 personas más completaron esta guía.
