Saltar al contenido principal
Nook Color Battery Replacement
Qué necesitas
  1. Nook Color Battery Replacement, Back Cover: paso 1, imagen 1 de 2 Nook Color Battery Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Battery Replacement: paso 2, imagen 1 de 2 Nook Color Battery Replacement: paso 2, imagen 2 de 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Battery Replacement, Front Cover: paso 3, imagen 1 de 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Battery Replacement: paso 4, imagen 1 de 2 Nook Color Battery Replacement: paso 4, imagen 2 de 2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Battery Replacement: paso 5, imagen 1 de 2 Nook Color Battery Replacement: paso 5, imagen 2 de 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Battery Replacement, Battery: paso 6, imagen 1 de 2 Nook Color Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the tape which holds the wiring to the battery using a plastic opening tool.
  7. Nook Color Battery Replacement: paso 7, imagen 1 de 3 Nook Color Battery Replacement: paso 7, imagen 2 de 3 Nook Color Battery Replacement: paso 7, imagen 3 de 3
    • On the back side of the middle panel, pry the battery using the plastic opening tools.
    • Use of force is necessary since the battery is glued down.
  8. Nook Color Battery Replacement: paso 8, imagen 1 de 2 Nook Color Battery Replacement: paso 8, imagen 2 de 2
    • Slide the connecting wire through the opening of where the battery was placed.
Conclusión
4 personas más completaron esta guía.
John Goly
Miembro Desde 01/20/15
490 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 11-5, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 56
Todo El Tiempo: 2,839
