Saltar al contenido principal
Noma Pedestal Fan Blade Replacement
Qué necesitas
  1. Noma Pedestal Fan Blade Replacement, Fan Blade: paso 1, imagen 1 de 2 Noma Pedestal Fan Blade Replacement, Fan Blade: paso 1, imagen 2 de 2
    • Undo the clips on the outer edge of the fan.
    • Make sure the fan is disconnected from the power source before starting.
  2. Noma Pedestal Fan Blade Replacement: paso 2, imagen 1 de 2 Noma Pedestal Fan Blade Replacement: paso 2, imagen 2 de 2
    • Gently remove the front piece by pulling it towards the bottom.
    • Don't pull too hard to avoid damaging the clips on the fan.
  3. Noma Pedestal Fan Blade Replacement: paso 3, imagen 1 de 1
    • Turn the cap clockwise and remove it.
  4. Noma Pedestal Fan Blade Replacement: paso 4, imagen 1 de 3 Noma Pedestal Fan Blade Replacement: paso 4, imagen 2 de 3 Noma Pedestal Fan Blade Replacement: paso 4, imagen 3 de 3
    • Lightly pull the faulty blade towards you.
    • Be careful while pulling to not injure yourself.
  5. Noma Pedestal Fan Blade Replacement: paso 5, imagen 1 de 2 Noma Pedestal Fan Blade Replacement: paso 5, imagen 2 de 2
    • Insert the new fan blade onto the screw .
    • Make sure it's pushed all the way back.
  6. Noma Pedestal Fan Blade Replacement: paso 6, imagen 1 de 2 Noma Pedestal Fan Blade Replacement: paso 6, imagen 2 de 2
    • Place the cap on the screw and tighten it by turning counterclockwise.
  7. Noma Pedestal Fan Blade Replacement: paso 7, imagen 1 de 2 Noma Pedestal Fan Blade Replacement: paso 7, imagen 2 de 2
    • After placing the front piece back on, fasten the clips again.
    • Make sure you align the piece to fit perfectly on the top.
Conclusión
This is a relatively easy process and as long as you follow our step-by-step guide it should be easy to fix.
Una persona más ha completado esta guía.
Taha Hashmi
Miembro Desde 01/15/24
172 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 369
