Saltar al contenido principal
Nokia X USB Port Replacement
Qué necesitas
  1. Nokia X USB Port Replacement, Nokia X Disassembly Prerequisites: paso 1, imagen 1 de 1
    • Remove the back cover of the device by applying light pressure toward the outer rim and display.
  2. Nokia X USB Port Replacement: paso 2, imagen 1 de 1
    • Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
    • The M2 screws are shown in red.
    • The M1 screws are shown in orange.
  3. Nokia X USB Port Replacement: paso 3, imagen 1 de 1
    • Gently separate the display from the chassis.
    • Slowly spread the display and chassis until the inside of the device is reachable.
    • Do not pull apart.
  4. Nokia X USB Port Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Spudger
    $2.99
    Comprar
    • Using the spudger tool, release the top flex ribbon from the light swap package.
  5. Nokia X USB Port Replacement, USB Port: paso 5, imagen 1 de 2 Nokia X USB Port Replacement, USB Port: paso 5, imagen 2 de 2
    • Again, using a spudger tool, release the rear facing camera from the light swap display.
    • Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
  6. Nokia X USB Port Replacement: paso 6, imagen 1 de 1
    • Using a soldering iron, desolder they broken USB port.
    • Solder your replacement USB port onto the light swap package.
Conclusión
6 personas más completaron esta guía.
Josh Perino
Miembro Desde 03/04/17
436 Reputación
2 Guías creadas
Equipo
IUPUI, Team S7-G7, Wilson Spring 2017 Miembro de IUPUI, Team S7-G7, Wilson Spring 2017
IUPUI-WILSON-S17S7G7
3 Miembros
8 Guías creadas
Un comentario
my mobile usb port no pls replacement
Giri GOWDA Nature RIDER - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,362
