Introducción
Use this guide to replace the entire display assembly on your Nokia X.
Qué necesitas
The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
29 personas más completaron esta guía.
