Saltar al contenido principal
Nokia N900 USB Replacement
Qué necesitas
  1. Nokia N900 USB Replacement, USB: paso 1, imagen 1 de 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: paso 2, imagen 1 de 2 Nokia N900 USB Replacement: paso 2, imagen 2 de 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: paso 3, imagen 1 de 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: paso 4, imagen 1 de 2 Nokia N900 USB Replacement: paso 4, imagen 2 de 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: paso 5, imagen 1 de 1
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: paso 6, imagen 1 de 1
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: paso 7, imagen 1 de 1
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: paso 8, imagen 1 de 1
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
Conclusión
3 personas más completaron esta guía.
Troy Posey
Miembro Desde 03/13/14
349 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 2,581
