Saltar al contenido principal
Nokia N900 Slider Assembly Replacement
Qué necesitas
  1. Nokia N900 Slider Assembly Replacement, Slider Assembly: paso 1, imagen 1 de 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 Slider Assembly Replacement: paso 2, imagen 1 de 2 Nokia N900 Slider Assembly Replacement: paso 2, imagen 2 de 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 Slider Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 Slider Assembly Replacement: paso 4, imagen 1 de 2 Nokia N900 Slider Assembly Replacement: paso 4, imagen 2 de 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 Slider Assembly Replacement: paso 5, imagen 1 de 1
    • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
    • To locate the slider, find the "black tape" on the screen half of the phone.
    • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
    • Once you have completed these steps your phone should be able to slide up and down with ease.
Conclusión
Una persona más ha completado esta guía.
Troy Posey
Miembro Desde 03/13/14
349 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 936
